3 minutes ago, Tasi3gaming said:
My pc has been shutting down for the last 15 min.I sadly resort to pressing the power button and forcing it to shutdown
This issue has been happening on every shutdown
Is there anything i can do to resolve it?
Boot into safe mode and try it. If it works in safe mode, something is wrong with windows. Sounds like a process is holding up the shut down sequence. Check the event viewer also.
PC - i7 12700K | EVGA FTW3 3090 | Corsair H150i | ASUS ROG Strix Z690-A | 32GB Corsair Vengance | Lian Li O11 Evo & EVGA 1k PSU
If my post solved your problem/answered your question, please consider marking it as "solved"
https://linustechtips.com/topic/1200382-please-help/#findComment-13646314
