1 minute ago, jonahadami said:
Thats not really a number.
I asked because I think you shouldn't invest too much money in such an old plattform
I guess you're right, but i really have no budget at the moment to invest in a new one, and instead decided to replace the cpu
https://linustechtips.com/topic/1200307-will-it-work/#findComment-13645817
3 minutes ago, Raptrozz said:
Also, would a re-install of Windows be needed?
Not if you keep the same drive.
Well thats a reason
Windows 11 Pro 22H2
Ryzen 3600
Gigabyte B450M DS3H
GIGABYTE RTX 2080 GAMING OC
G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
https://linustechtips.com/topic/1200307-will-it-work/#findComment-13645825
