I am building a custom case that has 2 motherboards in it. I want all the CPUs and GPUs watercooled.
System 1:
MSI Z370 SLI PLUS
2x EVGA 2080 Tis (XC with EK water blocks added)
I7 8700k OC to 4.9
System 2
ASUS Z9PED16/2L
2x E5-2697 v2
2x EVGA 1070 (EK Water blocks)
I currently have this pump:
https://www.ekwb.com/shop/ek-xtop-revo-dual-d5-pwm-serial-incl-pump
If I go with 2 separate loops, I would need to sell that pump and buy 2 more regular D5s or something. I would like to not do that. So my thoughts were to create 1 big loop or put a splitter coming out of the pump and split between the 2 systems, and another splitter on the inlet of the res so that they come back together.
is this a dumb idea?
Both systems will always be running and they can both be powered down at the same time.
https://linustechtips.com/topic/1200205-dual-system-waterloop-question/
Isn’t a dual loop if you only have one pump.
But it’s strong enough to handle them both, assuming the average amount of rads are being used.
I’d be more concerned about pump trigger unless it will always be on the primary system which will always be running.
