I'm building a PC with a Ryzen 5 3600, but i cant decide which graphics card will run well with it, I don't want the best possible as theyre too much money for my budget atm but i will probably upgrade it in the future. Any recommendations to a solid graphics card? Thanks.
https://linustechtips.com/topic/1199914-help-me-decide/
Go to pc part picker sort by lowest price and find what's in your budget.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1199914-help-me-decide/#findComment-13642883
