I'm really struggling to fix my audio desync issue, I've been trying for days... :( (List of stuff I've tried below)
The Problem: Audio Desync
Whenever i watch anything, YouTube, Amazon Prime Video, Netflix, after about a minute of watching it begins to desync like a badly dubbed film, and it gets worse and worse, refreshing fixes it for another minute until it starts again, its impossible for me to watch or enjoy anything, and it really sucks, especially during lock down (sorry for my excessive use of ,commas, I'm asthmatic)
Stuff I've tried
- Different browsers (Edge, Opera, Chrome) DIDN'T WORK
- Different Drivers (Old drivers, new drivers, windows generic drivers) (Even Graphics Drivers!!) DIDN'T WORK
- Different Cables DIDN'T WORK
- Changed setting in chrome like 'Hardware acceleration' DIDN'T WORK
- Fresh Install of windows DIDN'T WORK
- Different settings in windows (Stuff like Bitrate and the 'Hz') DIDN'T WORK
- Different speakers (More on that below)
I've tried so much stuff and nothing has worked...
Now about the different speakers, i've tried loads of different speakers and they all have the same issues, expect from my monitors inbuilt speaker (But its trash) and my monitor sound is controlled by 'NVIDIA High Definition Audio', where as the others are 'Realtek(R)' , so that would leave you to believe its something to do with Realtek but I've tried a bunch of different drivers and settings on that front and nothing works.
So I'm just really stumped at what the issue is and its driving me crazy, if anyone can help me with this i would be eternally grateful, I've head this forum is super helpful so my hopes are high.
Useful Info
Motherboard: Gigabyte B360N WIFI
CPU: i5 9400f
GPU: Gigabyte GTX 1060 3gb
Windows Version: 10.0.18363 Build 18363
Realtek Audio Driver Version: 6.0.8703.1
Graphics Driver Version: 445.87
Thank you.
https://linustechtips.com/topic/1199814-urgent-help-needed/
5 hours ago, xhackforeverxdx said:
Maybe the Soundcard on your Board is just broken u could maybe try to get the Audio from your Monitor via aux ( if the Monitor has a headphone jack at the back ) and connect it to your sound system
I've tried doing this just now but sound won't come out of the speaker, how do i get it to work?
https://linustechtips.com/topic/1199814-urgent-help-needed/#findComment-13643340
Did you change the output in windows to your display?
Did you make sure your display has the audio output enabled, or the volume turned up?
https://linustechtips.com/topic/1199814-urgent-help-needed/#findComment-13645576
