My dads computer is getting a blue screen after boot up we think it is because the cpu is over clocked a bit to high.
My question is if you have a over clocking tool in the os will it over ride the over clock you set in the bios. in my case it is just the spec clock speed
If so how can i remove the os clocking tool
https://linustechtips.com/topic/119972-overclock-problem/
I would venture to guess that the BIOS overclock will override the software overclock. Try booting into the bios and reseting everything to factory settings. What software utility is being used for the overclock?
Worship the Lord GabeN for he is your one true god!!!!
The Lord's Prayer
https://linustechtips.com/topic/119972-overclock-problem/#findComment-1598153
please list system specs. can get a better solution if members knew what they
were working with.
system should boot to BIOS easy enough, load optimized defaults and try from
there. it should overwrite any software changes.
https://linustechtips.com/topic/119972-overclock-problem/#findComment-1598365
