so i set up my pc and ran the bios and it still doesn’t turn on anything i made sure everything was plugged in i’m using a ryzen 7 x3800 my mother board is a asus corsair 6 hero and it doesn’t work i ran the bios with and without the cpu and etc any ideas?  cable management i didn’t really do it because i doesn’t work  and the start doesn’t change it stays red
https://linustechtips.com/topic/1199352-need-more-help/
not sure what you mean by this.
The Crosshair VI Hero is an X370 motherboard, it has to be updated to at least BIOS 6808 (I think) for third gen support.
https://www.asus.com/us/Motherboards/ROG-CROSSHAIR-VI-HERO/HelpDesk_BIOS/
Might as well make it as up to date as possible, or at least flash somewhere around 7201.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638843
i did that and it still doesn’t
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638856
what version are you running? Did this motherboard work with a different, early gen Ryzen CPU before?
Thankfully, if the BIOS flash failed, you can simply use the BIOS Flashback button with a different BIOS version and try again. Have you tried multiple versions?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638866
idk it’s brand new i can try new version
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638897
You definitely want to try different versions, maybe even older versions and then flash to newer versions after that instead of trying to flash the newest version by itself.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638906
okay will try after it’s done the blue light turns off do i just unplug it or keep it there and turn it on
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638912
I don't know the exact board behavior with BIOS flashback but leaving it in sounds fine.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638917
This was asked earlier, but did this machine work with an older CPU before? Or is this a completely new setup?
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1199352-need-more-help/#findComment-13638995
