It’s my first time buying a pc and i got a hero 6 wifi from asus and it says it need a bios update according to there website but when i do the light flashes for a little bit then it goes solid and according to people it’s not suppose to but idk what to do and i just want to be able to build my pc help me please before it’s to late to return the stuff thanks
https://linustechtips.com/topic/1199277-need-help/
What is your cpu ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1199277-need-help/#findComment-13638381
Is it the crosshair or the Maximus?
if it’s the Maximus, the socket is not compatible with a ryzen cpu.
if it’s the crosshair, it’s an x370 chipset so it will require a bios update to be compatible.
id recommend you switch it out for an X570 tuf, so you have no need for a bios update and guaranteed 4th gen support.
https://linustechtips.com/topic/1199277-need-help/#findComment-13638404
