I had purchased a nvme ssd (SP256GBP34A60M28) and my idle temps went up is this normal? It's not by a lot around 5-7c with my cpu and gpu but the temps are normal when gaming is this normal? I would like to add some top exhaust fans to my case seeing how i have 3 intake 1 exhaust but my motherboard only supports 4 case fans 1 cpu fan and 1 pump fan is it possible to connect more than 1 fan to a fan header? I am uncertain seeing how some people say yes and some people say it could damage the motherboard. I did read i could use the pump fan header but that would set the fan to run at full power which noise isn't really an issue for me.
https://linustechtips.com/topic/1199128-higher-temps-after-installing-nvme/
You could get lower idle temps by adjusting fan curves. Addding another heatsource will raise overall case temp. Adding another exhaust won't help that much, but might get temps bit lower. Could you post screenshot of your temps? Also pic of your case could be helpful.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
