really depends on how much you are willing to spend, there are some good hobbyist options that have OLED displays, but the price of those can be really high.
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
if you want to spend a reasonable price (for my hobbyist kb with non amazing specs, i spent like 250-300) i'd look at the Steelseries apex 7. (not the apex pro, from looking at the website the only "benefit" of that model is some weird switches that to me look worse). That one is $150, and seems to have some cool things you can do with the display. - https://steelseries.com/blog/steelseries-oled-gifs-and-customization-137
Theres also a ten-key-less version for $129, which could be a better option if you don't use the numpad
CPU: AMD 3600X
PSU: EVGA B3 650@
Case: NZXT H510
Thank you for the link!
I saw the keyboard and it seems good but that display isn't enough... Thank you replying!
Do you know any external displays that can do what the G15 Display can do?? (I'm not referring at a mini display that can act as a 2nd monitor)
what can your G15 display be used for? its pretty old so i didn't see much info about it online.
CPU: AMD 3600X
PSU: EVGA B3 650@
Case: NZXT H510
