So im looking for a 120g or 128g ssd to run os and maybe one or two games i play alot on and all my applications then i need a 1tb hdd to install steam games and such on.
Im wonder right now performance wise what is top ssd? I was looking at all these.
People say samsung is best but Crucial seems be good value
http://www.newegg.ca/Product/ProductList.aspx?Submit=ENE&N=100006693%20600038484%20600038478&IsNodeId=1&name=128GB
Also what should i get for hhd i just want fastest one possible to install and load games off of.
https://linustechtips.com/topic/119850-help-choosing-storage/
The fastest SSD on the market overall is the Samsung 840 Pro. It has one of the fastest read times, and a blazing fast write time too.
As far as HDD's go, the WD black is the way to go for performance. It is designed for games and overal fast read/write times. [source]
//ccap
https://linustechtips.com/topic/119850-help-choosing-storage/#findComment-1596876
Then go for the cheaper one. Unless you need the features of the 840 Pro (namely the MLC flash for high-write endurance), just buy whatever drive is cheapest per gigabyte.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/119850-help-choosing-storage/#findComment-1597167
Umm ok im also considering getting the 500g evo. I want know your guys thoughts if i can drop the 300$ you think it worth it right now?
Im not someone who needs back up large amounts of files this pc i use is 100% just games and downloading movies and is a media hub i dont do any type work or need large files on it.
So think its worth getting thr 500g to ditch hhds all together?
https://linustechtips.com/topic/119850-help-choosing-storage/#findComment-1597243
http://ca.pcpartpicker.com/p/2JWO5
There are faster ssd's and hdd's but you won't be wanting to stick a velociraptor in your system and the fastest ssd's are very expensive while not being that much better than the 840 Evo ...
Not for general use. Modern ssds are pretty similar for that.
If you need the speed and don't mind spending the cash , sure. I doubt you do though.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/119850-help-choosing-storage/#findComment-1598126
