this is normal of some motherboards.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631642
1 minute ago, Another_Blood said:
But is recomended enable or disable? I sus for life time Pc
it's not really something you can disable
Primary PC:
PSU tier list
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631693
2 minutes ago, Another_Blood said:
In bios is option for enable or disable ErP
does this change the behavior? if ErP is on, does the twice-booting not happen?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631806
With Erp activated double start occurs, with erp deactivated no double start occurs
for this say the question for double start is bad for life Pc or not
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631889
If ErP is causing this, might be some problem with ErP so you should leave it off.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631904
ERP is a power saving feature.
When you have it activated it cuts all power to almost everything in the PC when it is off.
Having it off means your PC still receives power when the computer is off.
Using either setting is your choice. Do you want to save power? Then have ERP on.
Do you want USB ports activated when your computer is off? Then have ERP off.
Now does the double power cycle harm your computer?
No. No it causes no harm. This is very typical on Asus motherboards, and can happen on others.
8/10 it's optimising memory training. Nothing to worry about.
It's not a race to the bottom.
https://linustechtips.com/topic/1198369-problem-bios-and-pc/#findComment-13631989
