You can if you are using 2 seperate connections for both.
For instance DVI for your computer and HDMi for xbox.
CPU:
Intel Core i5 2500k - Motherboard: Asus maximus iv gene-z - RAM: 2x Corsair Vengeance Blue 4GB DDR3-1600 CL9 - GPU: ASUS GTX 770 DirectCU II
Case: Coolermaster Centurion 5 II - Storage: Crucial M4 128GB, Seagate barracuda 3TB PSU: XFX 650W XXX Edition Modular PSU - Keyboard: Ducky Shine 2 Pro
Mouse: Razer Deathadder 2013 - Sound: Razer Characias
https://linustechtips.com/topic/119745-2-monitors-problem/#findComment-1595650
You can if you can connect them both. Then you just need to switch input in monitor settings.
https://linustechtips.com/topic/119745-2-monitors-problem/#findComment-1595658
My PC goes into the DVI of both my monitors but on my second one my PS3 goes into the HDMI so I can watch dem blurays and continue browsing on the primary monitor. Just gotta change the input when I use the PS3.
|| Processor: AMD Ryzen 5 2600 || RAM: 32GB (4x8GB) Corsair DDR4 Vengance (3000) || Motherboard: ASUS Prime B450-Plus || Graphics Card: Gigabyte RTX2070 || Storage: 750GB SSD (2 Drives), 3TB HDD (2 Drives) || Case: NZXT H500 || Power Supply: be quiet! Pure Power 11 600W ||
https://linustechtips.com/topic/119745-2-monitors-problem/#findComment-1595706
