Hii
My specs:
Lenovo Ideapad L340 gaming 15 inch laptop
intel i5 9300h
Gtx 1650 mobile
8gb ddr4 2300mhz single channel
1tb HDD
So I have been having problem with my graphics card since recently...A few months ago i used to hit around 80fps on low in witcher 3 then a few days ago it dropped down to 20-30fps idk what was the reason and also my system started performing very slow so i thought of underclocking my cpu and gpu and watched a youtube tutorial of a guy who had the same laptop with the same specs and in his video i saw that his GPU base clock is around 1395.0 MHz whereas my GPU base clock is 300.0 MHz still did underclock my cpu and gpu as shown in the video and now my system runs comparatively smooth and my laptop doesnt heat up anymore but when i try to run any game its stuck at 1fps , the main menu and loading screen are proper but when the actual game starts its stuck at 1 fps and the game is actually running i can hear the audio pretty smooth just the game is slowly changing the frames in 1 fps
pls someone help me what to do
https://linustechtips.com/topic/1197299-gpu-issue-please-help/
Wait what did you underclock to? Your card does not have a base clock of 300Mhz. It is also 1395Mhz like you can see under "max". Your card was just running at 300Mhz because your rig was at idle, so it wasn't being used. If you underclocked your card to 300mhz or under, your GPU will essentially be useless. Run it back stock, turn your fans up, and tell us what your temps/fps are while playing.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13623370
I took this screen shot while the game was running when its idle both base and max clock are at 300mhz and right now i have put everything back to stock but i still face the same issue and the in the video the guy had his base clock at 1395 mhz while his system was idle
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13623400
Also before i underclocked my GPU this was the same result i just didnt take a screenshot then as i thought maybe underclocking might solve the problem
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13623404
I can absolutely, without a doubt assure you the base clock on the 1650 isn't 300Mhz. Run it stock so you're getting the same FPS you were originally, run your game for a few minutes, and tell us the fps/temps you are getting, for both CPU and GPU.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13623592
i already did turn it back to stock but im still getting the same results...i just turned the gpu undervolt to stock not the cpu should i do that??
also i did disable my integrated graphics did that cause any prob??
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13624323
If you're using a 1650 then integrated graphics shouldn't matter, and should be disabled. Turn EVERYTHING back to stock, GPU, CPU, RAM, anything that's different, bring it back to stock clocks and voltages, and run your game, and tell us the temps and fps.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13624673
Already turned everything back to stock just the integrated graphics are disabled...should I enable it??Also I didn't disable it via bios but instead I disabled it using the device manager. Do u think there is possibility that it has not been disabled properly ??
Also thanks for your help man u are really great 🙌
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13624741
What are your FPS/Temps/CPU & GPU Usage %s?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13624756
FPS stuck at 1FPS as the main game begins during main menu it's normal / Temp is around 88-90 and CPU usage is 90% while the GPU shows 0%
Are all your drivers fully updated? Have you tried other games? And did it only start doing this once you underclocked everything?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13625099
I did try other games like gta v and Borderlands the same happend with them...they were working perfectly before under locking also I tried to play bastion a not so demanding game and it showed the same result
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13626466
What exactly did you do when you underclocked both things, as well, like i previously asked, are your drivers fully updated.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13627321
Okay so did enable my integrated graphics card and that help my gpu is now working also i ran a cinebench r15 test i got 73.38fps on OpenGL tho i checked in the task manager while i ran the test and my GPU was only utilizing 39-40%
https://linustechtips.com/topic/1197299-gpu-issue-please-help/#findComment-13630972
