Hey evryone, I'm new here in this forum And I have a problem in my last build:
In the last week I build a computer by my own by the following spec:
Intel Core i5-9600KF
scythe mugen 2 rev. b - CPU cooler
Gigabyte Z390 Gaming X
GTX 1080 advanced
32GB of RAM
750 power supply
Samsung SSD - sata
After I turned on the computer, it turned on but there was no post from the computer on the screen, and the computer started to shut down and turn on several times.
In the error led status its show me that the CPU and DRAM not working, so I start to pull off one by one the stick Ram, but nothing really happen,
 and I also tried to clear the CMOS and still nothing happen.
https://linustechtips.com/topic/1197232-motherboard-not-post/
36 minutes ago, Neri098 said:
Hey, I'm new here in this forum And I have a problem in my last build:
GTX 1080 advanced
32GB of RAM
750 power supply
Samsung SSD - sata
In the error led status its show me that the CPU and DRAM not working, so I start to pull off one by one the stick Ram, but nothing really happen, and I also tried to clear the CMOS and still nothing happen.
First of all why the hell did you write this like this
This is painfully hard to read
Second of all what is that PSU what model is it and how is it
Second of all did you try 1 stick at a time and see if that helps
3rd please rewrite this post it is hard and painful to read
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1197232-motherboard-not-post/#findComment-13622888
i tried my best to fix the text here because i copy it from WORD document
1) The PSU its a Silencer 750 EPS12V 750W Quad/Black SLI 80 Plus - I don't think it has a specific model
2) yes i actually try every single stick RAM but same reaction from MB
https://linustechtips.com/topic/1197232-motherboard-not-post/#findComment-13622972
https://linustechtips.com/topic/1197232-motherboard-not-post/#findComment-13622976
Are these 32gigs of ram dual or quad channel ?
Build Log:
https://linustechtips.com/topic/1197232-motherboard-not-post/#findComment-13622980
