B450 tomahawk max
Go to solution Solved by Guest,
3 minutes ago, Dougie said:
What polarity to i use?
+ goes to + and - goes to -
There should be labels on the little case led and switch connectors. Match them to the above diagram.
The link is the motherboard manual which I pulled the picture from.
