https://www.amazon.co.uk/dp/B01MTDJ6VP?tag=pcp0f-21&linkCode=ogi&th=1&psc=1
That is the cheapest PSU I could find, £41, and it has a PCIE 6+2 pin, which is what I use for my GTX 970.
Buy my advice is to save up a bit more and buy a better one.
This one is £70 and is fully modular:
https://www.amazon.co.uk/dp/B00HHH8AA6?tag=pcp0f-21&linkCode=ogi&th=1&psc=1
Bear in mind that this thing will be touching everything else in your system bar the monitor.  RAM, Motherboard, Hard drives, SSDs and Graphics card.
Saving £20 here only to find it has fried your entire system is not good value.
https://linustechtips.com/topic/1196844-gtx-970-psu-problem/#findComment-13620507
Hard to get a decent quality PSU for £35 - £45 it looks like.
Better if you can extend the budget to £50- £60 range...
Be Quet! System Power 9 500W -- Tier B PSU -- £50
https://uk.pcpartpicker.com/product/b37v6h/be-quiet-system-power-9-500-w-80-bronze-certified-atx-power-supply-bn246
SeaSonic Focus Gold 450W -- Tier A PSU -- £55
https://www.scan.co.uk/products/450w-seasonic-focus-gold-hybrid-modular-80plus-gold-sli-crossfire-single-rail-37a-120mm-fan-atx-psu?utm_source=pc part picker&utm_medium=referral
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1196844-gtx-970-psu-problem/#findComment-13620735
