One of my memory sticks bit the dust this morning. So i'm looking at getting a new kit. I currently have 2x8GB G.Skill Ripjaws V, Asus Prime X-470 Pro and Ryzen 5 2600X. Since i'm buying a new kit, Since i'm getting a new kit, i'm also thinking of going with 32GB. As I do plan on doing more with my PC than just gaming in the up coming months.
So my issue is, I used that G.Skill memory configuration and saw this kit F4-3200C14D-16GTZN Trident Neo 2x8GB 16GB kit. But I want to get the F4-3200C14D-32GTZN which is the same kit but in 32GB. But the 32GB kit wasn't in the memory configuration. My concern is, will I have issues with the 32GB kit with my current setup? I'm also planning on upgrading once Ryzen 4000 hits.
I'm also open to suggestions but no Corsair. I would like to get a 3200 CL14 kit.
https://linustechtips.com/topic/1196039-memory-stick-bit-the-dust/
I would follow up on what svm said, those come with good warranty’s you should just save your cash because if you plan to upgrade to the ryzen 4000 series this year you’ll need a new motherboard (if they stay true to their word), I don’t think your current motherboard will have issues with 32 gigs of ram and honestly just buy it on amazon and do a 30 day return if it doesn’t, but I don’t see why it wouldn’t.
Unfortunately, I voided my warranty on them. They have been used in 3-4 different systems and have abused them.
I already have money put away for a new Ryzen 4000 cpu and motherboard.
I already looked on Amazon for the part number and the seller wants $510 for the kit. And I don't get anything off Amazon, unless it's sold and shipped by Amazon. While I can get it for $380 shipped from Newegg. I live in Canada.
