Built thoughts?
Go to solution Solved by iBabySlapper,
If you don't care how it looks, and you can't budge on budget:
On a 700 dollar budget, what do you guys think? (Note that how it looks means nothing to me personally)
https://linustechtips.com/topic/1196034-built-thoughts/
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/1196034-built-thoughts/#findComment-13613676
why no ssd? Why no fans? I recommend the Asrock B450M PRO4-F since its the same thing but with usb type c, 4 ddr4's, 2 pcie x16 and its the same form factor (micro atx) and its probably the same price (sorry im in eu and they both cost the same but i bet they cost around the same in us). BUT. If you can wait a bit more you can get the b550 mobos with further support for newer cpu's and and higher pcie bandwidth, or you can get a b450 but at even lower price.
https://linustechtips.com/topic/1196034-built-thoughts/#findComment-13613682
