You're going to have to provide a little more info than that if you want a helpful answer. Screen specs? Graphics card? Connection interfaces you're using? etc, etc...
Built a mid-range game-cruncher to run MS Word and Chrome because doing anything else just wouldn't have felt right. I've got 250 Watts of power that I don't need, 24 Gigabytes of RAM that I will never use, 8 unemployed threads and I'm happy.
https://linustechtips.com/topic/1195904-issue-with-3-screens/#findComment-13613329
You're using three Sanyo 40" TVs?
https://linustechtips.com/topic/1195904-issue-with-3-screens/#findComment-13613973
Swap the connections on the outer monitors and set the surround again. See if it swaps over or if the left side is still the issue.
https://linustechtips.com/topic/1195904-issue-with-3-screens/#findComment-13614041
Well 1080's  are quite cheap at the moment. But you should have other ports. Not sure which on you have but one of mine has 5 ports on it.
https://linustechtips.com/topic/1195904-issue-with-3-screens/#findComment-13617512
Then it could be the glitch that many have issues with on the game. Plenty of render issues. Supposedly redownloading the game is the only fix.
You narrowed down the card, cable and monitor. Which means it’s the software.
also the game naturally supports surround? You aren’t using a fixer?
https://linustechtips.com/topic/1195904-issue-with-3-screens/#findComment-13621708
