I can only find 1x8 sticks. I don't think websites sell 1x4 anymore. You could try to find one from a guy selling it.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609710
yea no trace for 4 gig sticks
either way they are kind of a wast of money
but there is a 2x4 kit that maybe it will be somewhat usefull
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609755
Are you upgrading your ram and adding more gb or building a pc?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609760
Just buy 2x8 sticks if you want the best performance and not f*ck something up. because putting 3 ram and especially if they are different you could have problems.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609764
Here, this is the same thing.
2.4ghz or 2400mhz may not be a XMP profile, but rather a Jedec profile. Most sticks have more than one Jedec profile the board will post from.
Either way, this will do 2133mhz just the same.
https://www.bestbuy.com/site/corsair-vengeance-lpx-4gb-2-4ghz-pc4-19200-ddr4-dimm-unbuffered-non-ecc-desktop-memory-black/5989002.p?skuId=5989002&ref=212&loc=1&ref=212&loc=1&gclid=Cj0KCQjwnv71BRCOARIsAIkxW9FIjafX0E4XugIK4803YfkPakUU62as6mzc7VGJmiP223k8zVM57pcaAiX5EALw_wcB&gclsrc=aw.ds
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609822
Quick question
How long did it take you to find it because j looked all around and I found nothing 😅
Build Log:
https://linustechtips.com/topic/1195501-ram-help/#findComment-13609836
