So i have a original nes, nes zapper, and duck hunt/Mario cartage im trying to play it on a LCD TV (yes i know the gun has a filter that makes it to where the gun cant see a flat-screen and the frame buffer on tvs stop the screen from  sending frames one line at a time) but is there anything i can do without modding the vintage hardware and spend as little money as i can PLZ HELP
https://linustechtips.com/topic/1195177-nes-help/
I believe there are certain things you can buy to make a flat screen work with light guns, but I'm not sure what or where they are.
Best bet to play any of the Light Gun games is to find a CRT. I bet you that you can get one for $20 or less.
https://linustechtips.com/topic/1195177-nes-help/#findComment-13607285
On 5/16/2020 at 1:01 AM, piercetorres said:
what if i was willing to mod the hardware
Really wouldn't get you anywhere, honestly.
https://linustechtips.com/topic/1195177-nes-help/#findComment-13622097
