I upgraded an dell Inspiron with an working Corsair VS. 650 and a GTX 760 from Asus.
however, with the new card, I don’t get any display whatsoever,
All the parts have been confirmed working. Here’s what I have done already;
- reset CMOS
- DDU old drivers
- reseat gpu
- reseat power
- use different ports
- update BIOS to latest version
- Cry
https://linustechtips.com/topic/1194203-gpu-not-working-help/
I’ve had issues with older monitors and older cards combined with newer drivers and newer OS.
 Things that might or might not matter:
the port type on the monitor.  There seems to be serious compatibility stuff with DVI. Hdmi seems reliable regardless but a lot less love is being lavished on dviD.
Age of the driver.  I had a monitor literally just turn itself off on loading several times when I upgraded.  The generic video driver no longer considers itself compatible with my monitor for one thing.
age of the OS build.  Win10 apparently has several versions and they don’t all work the same.
https://linustechtips.com/topic/1194203-gpu-not-working-help/#findComment-13599957
Might explain my problem, as I am using an old monitor, with DVI.
thanks will try!
https://linustechtips.com/topic/1194203-gpu-not-working-help/#findComment-13599960
thanks will try!
I added some other stuff to that earlier post as I thought of it.
https://linustechtips.com/topic/1194203-gpu-not-working-help/#findComment-13599963
Just now, Bobotie1 said:
Can’t find one, will go to tech store later this day.
btw if this works I will be so happy been struggling for 4+ hours and pulling my hair out questioning wtf could be wrong. Nothing on the internet about this either you are my hero man.
There are a couple options.
#1 what other ports do you have on your monitor besides dvi?
#2 if not, What kind of dvi is it (there are several)
https://linustechtips.com/topic/1194203-gpu-not-working-help/#findComment-13599993
