Control freezing
Go to solution Solved by ki8aras,
14 minutes ago, worry said:
So if that was not bsod or even app crash , just hang,can be game related?
yeah so the game crashed so its the game's fault
Never happened like this in this game,Control Remedy. I was able to run game 24 hours without issue. But Today game after 2 hours just freeze,hang up. Mouse not responding,keyboard not responding. CTRL ALT DELETE logout from system.Event viewer nothing about crash,no driver crash. Just simply game freeze hangs. Killed in task manager i.
I have 2080 Ti Aorus NO OC stock,9700K Stock.
Any ideas why that happened? My pc are stable. But i dont know if something is broken in pc?
It happened again,second time. I reproduced that.This time after 20 hours. All freezes,character stop moving,mouse not reacting,keyboard stop responding. All i can do is to CTRL ALT DELETE and kill game in task manager. No display driver crash,no app crash in event log. Only i can hear is music in background.
https://linustechtips.com/topic/1194199-control-freezing/
game crashes happen, especially after 20 hours of running full tilt
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1194199-control-freezing/#findComment-13599871
No but using your pc for 20 hours non stop isn't necessarily advised
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194199-control-freezing/#findComment-13599886
https://linustechtips.com/topic/1194199-control-freezing/#findComment-13599923
