1 minute ago, BradleyB. said:
Yes the integrated works, it's  also on an ultra wide monitor
OK, that's good.  The GPU should work.  Your PSU is powerful enough, it doesn't need PCI power so there is no other connections to make.
Do you have the driver loaded?
Yes the driver is loaded it posts for a second the MSI brand but than nothing I can't go even go into bios
OK, so if I remember correctly, I had a similar issue with a 200GE I bought a while back.
Here is what I did-
Boot to the desktop with the integrated.
Hold left shift Key and go through the options to boot into safe mode.
Plug the monitor into the GPU and boot into safe mode.  I got into the safe mode desktop here.
I then used DDU to remove the driver from the system
I rebooted to the windows desktop with the gpu then and reinstalled the driver.
This worked for me a while back.
Here is what I did-
Okay I'll try it thanks for the help :)
