7 minutes ago, DanielSanta said:
Hello everyone so i am playing fortnite and i have i3 7100 nvidia gtx 1050 and 4 ram and textures are not loading is it bottleneck and if it is what i can do? can i do something without chanching parts? SORRY FOR BAD ENGLISh
What do you mean by textures are not loading? can you make a screenshot ?
did it use to work before on the same system?
Download DDU run it in safe mode then install the latest drivers from nvidia website.
If that did not help reinstall the game
if that did not help then further troubleshooting is needed but please do what I suggested above first and we will go on from there.
This could fix it
But it is most likely not loading because of the memory buffer , 2gb of vram is simply not enough for today
Phone: Pixel 3a (Purple-ish).
Build Log:
do you mean you have 4GB of ram or 4 sticks of _GB of ram?
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
I think he meant 4gigs (my assumption)
Build Log:
https://www.epicgames.com/fortnite/en-US/faq
recommended specs is:
Nvidia GTX 660 or AMD Radeon HD 7870 equivalent DX11 GPU with 2 GByte VRAM...so your gpu is just nice on the dot...
Core i5-7300U 3.5 GHz...you cpu should be better...both are 2 cores 4 threads...
8 GByte RAM...you only had minimum ram at 4GB...
after looking through all these my guess is you need more ram...xD
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
2 minutes ago, papajo said:
yea not doubt a GTX 1050 should be able to play that game and at a high framerate on top of that.
Now I don't play fortnite but from what I heard from my friends textures in that game do sometimes glitch and not load properly
So it could be just the game or the drivers
But I have my money on not enough ram
4gigs is simply really bad for today
Build Log:
Not at all 4gigs are enough for 1080p and fortnite in particular uses somewhere about 2.5 to 3 GB of vram on epic settings 1080p (less than 1,5 GB on low to mid settings)
https://youtu.be/0joc8t6z0JQ?t=821
Oh no I meant dram not vram lol
Build Log:
my pc idle at 4.5GB ram...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
Yes that's the point OP is severely bottlenecked
Build Log:
ohh..i quoted the wrong guy...i meant to quote the 1 saying 4GB rams is not the problem..haha...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
That's because it has more vram available it caches more stuff in advance for efficiency   reasons  btw I just showed you a video running a 1050 ti at epic settings and it used ~2.5GB of Vram and there was no texture issue lol
It's ridiculous to think that a fairly modern GPU cant play a game from 2017 which doesnt have that much demanding graphics anyway
its minimum requirements  is a intel hd 4000 IGPU....
635210314_fortnitefortnite.thumb.jpg.45b2b8498f28d3c7cef78568a4f5fdb4.jpgthis is not my screenshot but its the same happening i cant enter houses and etc. pickup guns emote or other stuff AND YES IT WORKED FINE ON THE SAME SYSTEN BUT SEASON CHANGED AND THEY USED ANOTHER ENGINE TOO RUN THEIR GAME. i reinstall the game same thing i have like 244 fps ping 5 but graphics doesnt load
Edited by DanielSanta
well then its better to contact epic games support https://www.epicgames.com/help/en-US/fortnite-c75
Since the fact that you reinstalled the game and didnt work while you are not able to open doors (because if it was just a client side issue -the client in our case is your pc- and things didnt get rendered good then it doesnt mean that a door cant be triggered if server knows a door is there on your location and you click the "open" button, so its probably a bug related to the game itself rather than your GPU or its drivers or the rest of your system)
But as I said you could try to download DDU and run it on safemode and then reinstall the latest drivers you can download from here https://www.nvidia.com/Download/index.aspx
to check if it will help anything
what you could also do is push the windows key + R
on the new window type dxdiag and push enter
if on the new window no error is found then go microsoft's page for downloading DX runtime https://www.microsoft.com/en-us/download/details.aspx?id=35
download it and run it (careful there is a checkbox that asks you to install bing bar... which I guess you wouldnt like so uncheck it)
this will verify and download if necessary any missing/altered dx files
