[HELP NEEDED!] Question about component compatibility...
By
TheEgg6969420
in Cooling
in Cooling
Solved by PorkishPig,
18 minutes ago, TheEgg6969420 said:
You can't remove that top heat sink, it will kill the board. It seems that your only options would be to mount on the right, or purchase a different cooler.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory4 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
