I need help....
Go to solution Solved by starry,
Just now, RadiatingLight said:
Just cut around the controllers I guess
or that
So this is going to seem like a very stupid question but it is seriously. So i have a membrane keyboard (Logitek k120) and the numberpad i just cant handle, I find it is in the way of my right hand with the mouse. So is it possible to basically cut the numberpad off? It is only a $12 AUD keyboard so not much to lose....... and a new keyboard aint a option as i really cant afford one
~Thankyou
-Medium
https://linustechtips.com/topic/1192509-i-need-help/
Highly doubt it, but I guess it depends on how the board is build and where the important controllers are.
Chances of success are low, but not zero IMO. Be prepared to buy a new keyboard.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587231
probably not, keyboards generally just have 1 big PCB with a chip on it and contact switches under the plastic shroud, and unless you know your way around a multimeter and know how that stuff works, its difficult to verify that it wont kill it
you could try though, i wouldnt if its your only keyboard
Here is the cheapest tenkeyless keyboard that looks okayish i could find if youre interested
https://www.amazon.com/Rii-Keyboard-RK104-Backlight-Computer/dp/B07RN5T3W4/ref=sr_1_24?dchild=1&keywords=tenkeyless+keyboard&qid=1589180113&sr=8-24
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587233
Laptop:
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587234
or that
Windows Gaming PC
120GB SSD
120GB SSD
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587237
Just now, ILLUMINATY said:
Also if you exposes any metal peaces or wires you can get electrocuted if you accidentally touche them.
They would most undoubtedly be doing it while the keyboard is unplugged so thats a non issue
Windows Gaming PC
120GB SSD
120GB SSD
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587245
i love it when i say 2 words and get called a legend, youre a legend too friend
Windows Gaming PC
120GB SSD
120GB SSD
https://linustechtips.com/topic/1192509-i-need-help/#findComment-13587249
