Looking for a recharging cable for a pair of Benq 3D glasses DGD5 (5J.J9H25.001).
Can't tell what kind of USB port this is. Is it UC-E6, or 8-pin mini-B plug?
https://en.wikipedia.org/wiki/USB_ha...onnector_types
Found a 8 pin Mini B cable, it's listed as 93972 part number. A google search says it's a Goobay cable.
https://www.amazon.com/Goobay-93972-.../dp/B003JG3KE0
However one review from Amazon says:
I bought this cable for charging LG 3D glasses (LG-AG-S250). Unfortunately not compatible. Connections fit, BUT there is no charging. 3 cables were tried out.
Is there some kind of special USB cable for 3D glasses?
Top - ?
Middle - Mini USB Type B
Bottom - Micro USB Type B
https://linustechtips.com/topic/1192126-cable-for-3d-glasses/
Whatever that is, it doesn't look like any official USB connector I've ever seen. I would assume that is something proprietary. Here's a list that shows all official USB connectors: https://www.cablestogo.com/learning/connector-guides/usb
By the looks of it, it could very well be UC-E6. Since it is non-standard, I guess the pin layout isn't standardized across brands either. So it's quite possible a cable from one brand doesn't work on another one (like the LG glasses you mentioned). Best bet would be to get the cable from BenQ directly.
https://linustechtips.com/topic/1192126-cable-for-3d-glasses/#findComment-13584356
  • 2 weeks later...
Got the cable. Does not mention Goobay. Listed as Onni-Tec GmbH OTB-DK001. Fit in the glasses connector but does not charge.
Managed to talk to Benq and got a cable from that works.
Benq top, OTB bottom:
https://linustechtips.com/topic/1192126-cable-for-3d-glasses/#findComment-13639493
