A CPU cant make any noices. Do you mean the Fan?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1191771-cpu-makes-loud-noise/#findComment-13581877
2 minutes ago, Bossshakib said:
Yes I guess so. Not sure whether its from GPU or cooling fan. What should I do in this regards?
Could be Coilwhine from the GPU.
A high pitching noise. If thats the case, it can be annoying, but is harmless.
Then Fan could be bearing, a lower, grinding noise. Onlly solution, replace the Fan.
https://linustechtips.com/topic/1191771-cpu-makes-loud-noise/#findComment-13581889
6 minutes ago, Bossshakib said:
Can I do something to reduce the noise?
Record the noice with your phone and uplaod it. If its bearing, just buy a new Fan. Coilwhine is nothing you can do about. Well, you could replace your Graphicscard.
https://linustechtips.com/topic/1191771-cpu-makes-loud-noise/#findComment-13581925
Not without telling us what’s actually causing the noise...
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1191771-cpu-makes-loud-noise/#findComment-13581974
When you say noise, that could be anything - Would help if you could describe it or do a vid as suggested.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/1191771-cpu-makes-loud-noise/#findComment-13582098
