Hey guys, I've been working at this for a while and I could really use a hand with this. I purchased a new PC and decided to give my old one to a family member. The day I gave him my pc it was working just fine, i had just reinstalled windows and installed some programs he wanted before I gave it to him.
Once he receives the computer, he tried to load into a game of csgo, and during the loading screen it just blacks out. The RGB lights are still on and the fans are still spinning. And the monitors are still receiving some sort of input cause the backlight stays on and doesn't display no signal.
All I can think of is a PSU Problem or maybe a heat shutdown, but I dont think it's a heat shutdown cause the fans stay running, and when my pc heat shutdown one time everything was off.
Thanks guys, any help is appreciated
-MickShinode
https://linustechtips.com/topic/1191705-psu-problem/
So many questions.
Specs?
What have you tried to fix it?
Will the computer reboot?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1191705-psu-problem/#findComment-13581318
13 minutes ago, Statik said:
So many questions.
Specs?
Intel Core I5-6402p
Radeon RX-480
WD Blue 1 TB
Msi B150m Bazooka
Thermaltake ttp-0600p-w
Ballistix Sport LT 16GB
All i did was allocate more power to the gpu to see if the gpu was not getting enough power and switched out the sata cable for the hdd with an extra i had laying around the house
it boots and works just fine but shuts down randomly, under load increases the odds of it shutting down.
https://linustechtips.com/topic/1191705-psu-problem/#findComment-13581470
23 minutes ago, MickShinode said:
Intel Core I5-6402p
Radeon RX-480
WD Blue 1 TB
Msi B150m Bazooka
What are your temps? And what do you mean you allocated more power to the gpu..?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1191705-psu-problem/#findComment-13581548
