Budget (including currency): 1500$ including monitor
Country: US
Games, programs or workloads that it will be used for: Mostly league of legends, Rainbow Six Siege, and Destiny 2
https://pcpartpicker.com/user/YOUR_FACSZ/saved/RffnLk  Would like to be over 100 fps don't care about rgb at all. All advice is welcomed. First build.
https://linustechtips.com/topic/1190907-need-help/
Country: US
Your PCPartpicker list is private :/
https://linustechtips.com/topic/1190907-need-help/#findComment-13575701
1 minute ago, YOURFACSZ said:
It's fixed
Solid build. I would just go with a 500 GB SSD minimum, and possibly a 2 TB harddrive instead. Both of those things will be very minor price uppers but especially the SSD would be worth it. 240 GB these days is enough for windows, and depending on the games, only maybe 2 games. For ~15-20 bucks you can likely double that to 500 GB and that just makes a lot more sense, especially considering the overall cost of the system... An extra ~20 bucks isn't much.
https://linustechtips.com/topic/1190907-need-help/#findComment-13575721
Thx so much for the help.
https://linustechtips.com/topic/1190907-need-help/#findComment-13575727
