 Can`t record or use overlay for some reason, the image includes the specs, all required specs are met , yet it shows this, tried reinstalling exp, updated the driver, also i upgraded 2 month ago from a 1050 ti to the 2070 super, before that it was all normal, i just tried exp today, forgot to reinstall it before. Also before i swapped the gpus i used DDU then installed the 2070 super and installed the drivers
Help pls!
EDIT: i did turn it off and on xd, didnt help :P
https://linustechtips.com/topic/1190656-geforce-experience-features-not-ready/
that is weird
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
5 minutes ago, wall03 said:
that is weird
For one moment i thought my gpu was fake, even tho i got it brand new and sealed
i even checked it with gpu z all is good, playing games normally on maxed settings and high fps , but this thing here is weird AF
it detects that it is a 2070 super
but req not met LOL
but req not met LOL
It looks like Nvidia simply released a bad driver, this is not uncommon. Others seem to have had the same issue with the 2070 SUPER, see https://www.reddit.com/r/GeForceExperience/comments/abouie/rtx_2070_shadowplay_not_working/. Try GRD 442.74 from https://www.nvidia.com/download/driverResults.aspx/158756/en-us.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
could be that, will try it later ,thanks
