I have a Dell Inspiron 5559. It loaded with i7-6500U ; 16GB 1600Mz Ram ; 1Tb Hard-Drive ; AMD Radeon R5 M335 4GB Gpu. I bought it 2 years ago. It worked fine. but now its giving me some issues. I used to get above 70+ fps in csgo at 100-95% Gpu usage and 80-60% Cpu usage. But now i get below 40 fps and it drops to 20 fps and below and laggs for like 40 second to about a minute. This happened to me when i disconnected the battery cuz its dead i'm running it on ac adapter. I used to get my older best performance when the battery was fine but it used to drain the battery and locks the computer with the low battery indication when the battery reached below 50%.This never happened to when i bought the laptop. I have provided a task manager screenshot of what happens to me right now (CSGO is running in the background) the gpu stays under 40% sometimes upto 60%and the cpu drops to as low as 1.00Ghz it is below base clock ,it boosts upto 2.99Ghz when I dont run any game. I cannot get any help from Dell cuz the laptop was imported from US .Please Help I am so fedup of this lockdown.1288922679_Screenshot(127).thumb.png.72066d097008bc5558ebd7b823768e5c.png
https://linustechtips.com/topic/1190618-help/
Try the following:
  • If your computer is entering Battery Saver prematurely, go into your Battery settings turning off "Turn battery saver on automatically if my battery falls below:". Get to this setting by entering ms-settings:batterysaver into Run (Win+R).
  • Make sure that your power settings are not entering "Power saver". Having this selected will severely limit your performance. View this setting by entering control powercfg.cpl into Run (Win+R).
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1190618-help/#findComment-13573294
Ensure you're not on battery save mode, and it's on "high performance" or whatever the options are. And I believe it's common for laptops to perform better while plugged in, so it could be a battery issue and just need to be plugged in to game on it.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1190618-help/#findComment-13573365
