I currently have an HP omen obelisk 875-0035qe that I got for $1,000 used. It has an Intel i7-8700 with an rtx 2080 but has a stock Intel cooler and a pretty basic HP motherboard. I don't have many issues with this build but the cooling
is actually horrible. I've been wanting to do a case swap and maybe get an AIO water cooler for my cpu. Any recommendations for a cheap good looking case / water cooler?image.png.0324905b677d788c0657f0723ab82601.png
https://linustechtips.com/topic/1190247-case-swap-ideas/
Fractal Meshify C with a 280mm+ AIO.
HP Edoras micro-ATX is the motherboard, as stated below by @SpookyCitrus.  May be an issue fitting it in the Meshify, not sure tho.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1190247-case-swap-ideas/#findComment-13570489
I believe the Obelisk(like all of the Omen line) uses an HP proprietary motherboard so you would likely have to get a new mohterboard as well, possibly even a PSU. As those two parts other than the case are not standard and will not work in a standard case. The PSU may fit but it more than likely uses a non standard 24pin or connectors.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1190247-case-swap-ideas/#findComment-13570490
  • 2 months later...
I was looking at water cooling on the same HP Omen but as the motherboard has to come out to achieve this I just swapped the HP Omen in to a Corsair Carbide Series 275R Mid-Tower ATX Gaming Case using the stock motherboard and added a Cooler Master Hyper 212 EVO CPU Air Cooling System with no issues, and all for about the same cost as a decent 240mm AIO water cooling system,  It now has 3 intake and 2 exhaust 120mm fans (had added a couple of extra fans to the Omen before), there are no additional fan headers so I have had to use splitter cables.
I chose the Corsair as the configuration of 2 x USB 3, power and audio sockets on the top of the case was as close to the HP Omen as I could find. Only the reset button on the case is redundant. I haven't fitted the Omen light board as I'm not to fussed about it but I may get around to it just to see if I can.
The hardest bit was removing the CPU cooler back plate as HP glue it to the motherboard. Just took my time and gently prised it off with a butter knife!
Before the CPU would hit mid 90's playing Warzone for 25 minutes, since the case swap it sits at 73 max.
https://linustechtips.com/topic/1190247-case-swap-ideas/#findComment-13887661
