So basically I was thinking of getting myself a new PC, to be more precise build one for myself, and I would like to hear your opinions of it, I already found all the parts and I'm gonna list them below,
Budget (including currency): Roughly around 1000-1300€
Country: Croatia
Games, programs or workloads that it will be used for: Mostly for gaming, playing newer pc games, like warzone and other upcoming pc games at 1080p, and some video editing maybe even streaming
List:
CPU: AMD Ryzen 5 3600 3.6GHz 6-Core Processor
MOBO: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard
RAM: Kingston HyperX Fury 16GB (2 x 8 GB) DDR4-3200 Memory
HDD: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive
SSD: Kingston A400 240 GB 2.5" Solid State Drive
GPU: Sapphire Radeon RX 5600 XT 6 GB PULSE Video Card
CASE: Zalman S3 ATX Mid Tower Case
PSU: RIOTORO ENIGMA G2 650W 80+ Gold Certified Fully Modular ATX Power Supply
I was also thinking about FreeSync compatible monitor, so I was thinking about
Philips 23.6" 248E9QHSB
So basically, if you guys know any better monitor, for similar price, or any change in the parts above, I'd like to hear them out. Thanks :)
https://linustechtips.com/topic/1190190-my-first-build/
Country: Croatia
List:
You are going to need a larger SSD, I would reccomend a 500 gig crucial P1, and all the rest seems solid, but I dont know what other monitor to suggest since I dont see it for sale anywhere so I dont know how expensive it is.
Laptop: HP Spectre x360 13t, i7 8565u with 16 gigs, 512 gig  nvme ssd, UHD 620 4k
Other laptop: Acer Chromebook cb3 431 with 4 gigs, celeron n3060 with hd 400 and 16 gigs eMMC soon to be a minecraft server?
Remeber to tag people or else they wont see your post.
https://linustechtips.com/topic/1190190-my-first-build/#findComment-13569997
Hmmm yeah, monitor is in one of the local stores here in Croatia, it's around 120-130€, and also, I thought that 240GB for SSD is gonna be enough for Windows and maybe couple of games, but yeah, I'll consider getting bigger if it's neccesary
https://linustechtips.com/topic/1190190-my-first-build/#findComment-13570284
Modern warfare is actually 120 gigs, maybe a slightly larger one. Since sata SSDs dont have moving parts, you can quite literally throw them anywhere in the case lol
https://linustechtips.com/topic/1190190-my-first-build/#findComment-13570440
