Need Help Merging Partitions
Solved by Electronics Wizardy,
9 minutes ago, Shuffle said:
Then the os sees those partitions as a system disk, so you need to delete the partitions in diskpart. So open cmd as a admin, then type diskpart. Then select disk 3(check the number is right by looking at the size), then clean.
