PC Part Picker will allow you to calculate what you need when you put the build together part for part on their site. I'd probably say 650 watt, can't imagine you'd need much more than that. I'm running a 9600k with 5.2 ghz across all 6 cores and an RTX 2080, also oc'd with a 650w platinum PSU
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1188967-help-picking-wattage/#findComment-13560874
18 minutes ago, Fecba said:
I need help picking a wattage and brand of power supply.
I am going to run a Ryzen 7 3700x, 5700xt 16gb of ram, and a 570x Strix-E.
I want fully modular as well.
(in Canada)
Thank you for any advice :)
50W for the base System
150W Max for the CPU
200W Max for the 5700XT
So you're just around 400W total but you should always leave room (say 200W) for expansion and try and run the Power Supply in the 40-60% load for best efficiency and lifespan and lowest noise.
I'd suggest a 650 or 750W unit, Seasonic, EVGA or Corsair are all brands I'd recommend. You can save a bit of cash going for a semi-modular like the Corsair RMx series where the Motherboard and CPU cables are all-black and wired versus the H or A-series.
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
https://linustechtips.com/topic/1188967-help-picking-wattage/#findComment-13560951
