So a while ago I found an old pc in the basement and I decided to take it apart clean it and try to fix it but I'm stuck. I have tried to reset the CMOS, tried new ram but nothing
heres the specs
MB: AsRock Conroe 1333-DVI/h
CPU: Intel core 2 Duo E6750
GPU: none
PSU: Random 500W unit
HDD: WD Blue
tnx for the help
https://linustechtips.com/topic/1188950-pc-wont-post/
Maybe PSU? The HDD could have failed
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1188950-pc-wont-post/#findComment-13560779
the new psu just arrived so I'll try that
1 minute ago, ISHAJDM said:
check all of your connections maybe the psu got so old it stopped working. Also check for bent pins in the socket
https://linustechtips.com/topic/1188950-pc-wont-post/#findComment-13560787
