Hello!
I have the logitech g403 prodigy and when I move it fast it just just stops for a bit and than goes back to working properly, I play on a microfibre mousepad.
I've always had this problem but it seems like it has become worse now.
I play on 600 dpi, increasing the dpi would definitely throw off my aim so I'm asking here before I do that.
I've tried reinstalling logitech g hub.
Here's a video of me showcasing the problem (note: the movements of my hand were just fast and smooth across my whole 1m mousepad, but in the video you could see stopping):
https://linustechtips.com/topic/1188479-mouse-stutter-when-flicking-problem/
Hmm watched this on a phone. Not sure it seems odd like you turned less it stopped. I had this mouse before. How long you had it though, check sensor for dust to be sure.
What's your polling rate at? Higher DPI won't affect your aim, you can always adjust in game.
You said it got worse, that's strange, maybe it's starting to malfunction and RMA it as last resort if you can.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
I've had it for around 1 year now,  the sensor is clean, polling rate is at 1000.
Hmm, try to lower it, change the mousepad. Uncheck the "Enhanced pointer precision" in mouse options if it's on. If it doesn't help, maybe it's faulty.
  • 5 years later...
hi there , i know its 5 years later but , i just got a Logitech G102 , and it has the same problem , i also play with low dpi , and when trying to flick either in cs 2 or valorant or ...., it just kinda stops and stutters , did u manage to find a solution for it or no .
I'm not experiencing this issue my self though. If it's not a mouse issue, then could be something else. I'd make sure first Windows installation is clean enough, up to date, updated drivers. Disable any program overlays for in-game use, use exclusive fullscreen option in game. I'm expecting it may not be PC specs maybe.
hey , thanks for replying . i actually just fixed it , just turned off "Enhance pointer precision" in mouse properties .
