I was recently given a i9 7980xe and Rampage VI extreme for free off of my good mates pop, he hadnt used them in a while and kept the motherboard and cpu in separate anti static bags. He says the board has never been used but the cpu was used. I replaced my current parts with my new parts and as soon as I plugged the cable into the wall the motherboards lights turned on but the gpu didnt, the fans didnt spin but there was no beeps of any kind. Does anyone have any ideas which could help me in any way. All parts that I didnt replace are still working perfectly fine, just not with the new parts. Thanks alot :)
https://linustechtips.com/topic/1188231-need-urgent-help-please/
it's possible that there's some compatibility issues with the ram, if you could borrow some DDR4 to test with and get it to work, you should update the BIOS to improve compatibility.
Primary PC:
PSU tier list
How many watts do I need?
The pc doesn't boot at all, no fans spin and the gou doesn't power up on the new parts but everything works fine in the rest of my build. Also none of the debug lights have turned on which is a bit worrying. Should I take it to a professional?
If that's an option, I guess. Not something that's so easy to do right now, though.
Primary PC:
PSU tier list
Take a few steps back: re-instate your original setup first. If the PSU is fried, it won't work. If it works, the PSU is good. Next, swap out the mainboard and CPU, using only 1 stick of RAM. Make sure it's in the correct slot. Don't add anything else, see if the system boots. If it does, add more RAM then the GPU. At some point it may become unstable or refuse to boot, undo the last change and try again with a different component.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
just tried that and nothing. the fans dont spin or anything
Try the cpu in your old system if it's compatible. If it boots then the stored board may have an issue caused by knocking, rattling, or pressure from other things stored near it.
my other system is ryzen so the cpu won't fit in it. none of the debug lights light up which is strange so im not sure hwats wrong with it
Which version of Motherboard. There's several listed under that name with different specs
11 minutes ago, bigsmellypoo said:
Yep, that was the first thing I did
Try doing it with all the hardware removed but the PSU still connected. I did a little more digging, so many no-post reports, and some of them were incompatabilities with ram and a few other hardware issues.
i reckon i'll take it to a proffesional to get it checked, dont want to stuff around with it too much. thanks for your help, ill keep you updated :)
Hope he comes to a different conclusion than I did. If I had told you to do failed I would have to advise you consider the board dead.
yeah thats what im worried about, you think it can be repaired if it is dead?
I honestly have no clue. My help comes from diagnosing and repairing my own desktop pc. Most of which are low grade parts I got years ago. Planning and saving for an upgrade though and figure I could learn more and help on LTT forums.
yeah thatnks for your help mate, really appreciate it. :)
