21 minutes ago, SlimShady20 said:
I recently heard my psu making strange buzzing sounds
Coil whine? Nothing dangerous, just annoying. There can obviously be some arcing when you connect and disconnect the cable, as there's 110/230V there. I don't see anything to be worried about
https://linustechtips.com/topic/1187797-psu-cable-burnt/#findComment-13553289
No, don't use button to turn off PSU routinely, only for prolonged periods or smth, otherwise the switch would worn out eventually.
Nothing bad with those arcing marks on the contacts but that may indicate that you don't plug the cable all the way.
Buzzing sounds may be just coil whine, it's harmless.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1187797-psu-cable-burnt/#findComment-13553430
I will order a new cable and try and see if it still does those sounds.
https://linustechtips.com/topic/1187797-psu-cable-burnt/#findComment-13553472
