Hi guys, im going to build a new gaming pc, it will be for games like cs go, gta v, lol, cod mw, far cry, god of war, witcher 3, and Im thinking about buying a Asus gtx 1660 super tuf x3 OC 6Gb, is it worth it to replace it for a MSI GeForce® RTX 2060 SUPER VENTUS GP OC 8 ? btw the price diference is 128 euros
This is the build:
CPU - AMD Ryzen 5 3600
Motherboard -MSI X479 Gaming Plus
RAM - Team Group Kit 16GB (2 x 8GB) DDR4 3000MHz Night Hawk Black RGB CL16
GPU-  ??? Crucial MX500 1TB M.2 3D
HDD - Seagate Barracuda 2TB 7200rpm 256MB SATA III
SSD - Crucial MX500 1TB M.2 3D
PSU - Semi Modular Corsair TX 650M 80+ Gold
Thanks!!!
https://linustechtips.com/topic/1187401-gpu-help/
1 minute ago, aDoomGuy said:
Normally I would say yes it is worth it, but maybe not for those games unless you aim for very high FPS? Well MW perhaps will benefit from a better card than 1660s.
Nah i actualy play most of the games on minimum/medium because i don't care about the graphics having to be at ultra or something, theyj just have to appear decent the only game I play at max its league of legends
https://linustechtips.com/topic/1187401-gpu-help/#findComment-13550433
1660s unless there are some games in the future you really want to play like Cyberpunk.
https://linustechtips.com/topic/1187401-gpu-help/#findComment-13550445
Ah not rly im going to play all those games and prob assassins creed but nothing to crazy and if I want to play some heavy game I think i'll be able to run it and minimum/medium graphics , and I also want to keep these build for the next 3 years. Thanks!
https://linustechtips.com/topic/1187401-gpu-help/#findComment-13550455
1660s should be able to, yes. I say should because I'm not Nostradamus hehe but if you don't want to pay extra for higher graphics settings then good for you! Tell you what though, ultra settings.. high settings.. I can't really tell them apart these days. :P
You welcome. :)
https://linustechtips.com/topic/1187401-gpu-help/#findComment-13550474
