hello every one
i bought Seagate backup hub 10tb from a month ago
I had two issues temperature and making unknown sound and i don't know is that normal or what
it makes sound on read most of time than write
i attached the sound
the temp reaches 48 c with normal use (no copy or past) and it reaches 61c on full load (my room temp 27 c)
I asked help from Seagate support 3 times but no one answer me
anyone can help plz
https://linustechtips.com/topic/1187293-seagate-backup-hub-10tb-issues/
It's a hard drive in a box with zero airflow, they get hot. The sound is concerning, but you can't really do anything on your own to fix it. Make sure the drive isn't your only copy of anything essential and keep trying with support is the only advice I've got.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
i found someone had the same issue
i don't know is this common issue
