I  have been wanting a pc for a while, so I saved up some money ($2000) to try and build one. Wanted opinions on these parts and if I should make any adjustments before purchasing the parts. My budget is $2000. I am also planning on using the Wraith Prism for CPU cooling.
https://linustechtips.com/topic/1186949-first-pc-build/
Well Nvidia might just release the new 3000 series in just 2 weeks so I'd honestly hold off at least until then, if you can.
Also my 2ct, don't get a $300 case... Get a decent $100 case instead and put another 200 towards the GPU.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1186949-first-pc-build/#findComment-13546825
what are you gonna be using this for?
https://linustechtips.com/topic/1186949-first-pc-build/#findComment-13549251
