Hello, today is the start to my new build
_____________________________________________________
Right now i am running off of my fairly new build, but i half-assed the case and power supply so i am re-doing it. My current build is as follows
  • Intel i7-3770k
  • Asus Sabertooth z77 motherboard
  • GeForce GTX 680 DCU II
  • WD caviar blue 1 tb x2
  • Corsair Carbide 500R
I added the following for Liquid Cooling
  • Swiftech Apogee HD Water Block
  • EK-FC680 GTX DCUII
  • Swifteck MCP655 Pump
  • Black Ice GT 240mm Rad
  • cheap 120mm rad
  • Alphacool 5.25" res
  • nice UV blue tubing
I really like this setup but there were a few problems.
  • hard to bleed because the res sucks air into the loop directly to the pump making it very loud
  • horrible tubing runs because it was my first time
  • horrible cable routing because  i rushed it
  • it makes me feel inadequate when there are people with better computers than me
So i am starting fresh (kinda)
My "new" build will have the same hardware except with:
  • new power supply to make it more quiet and easier to sleeve
  • new case (900D?) because i need more rad space
  • adding on another 680 maybe in the future to make it better
  • more rads because i want to run the fans slower
  • new res so the pump isn't always filled with air
By now some of you may be thinking I am over killing it but you have to remember water cooling and high end pc building in general is more about the fun of making it. I want to be able to be proud of my computer and make it look better than it is now.
I am looking for names for the new build. Its blue and black and nothing special so I'm thinking something simple for the name. It will be based in the 900D (maybe) and i think something like the obsidian name would be cool.
Any suggestions or comments are appreciated and i will update this as my plan changes (as they do so often in building).
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/11868-second-build-upgrading-first-build/
