hi all, covid-19 is here and this means i need a pc to stay at home not bored :D
1. Budget & Location
vancouver, bc (canada)
budget - $3000 - $3500 CAD (ideally less as possible towards < $3500 after taxes)
2. Aim
3d modeling, rendering
These applications will be used:
  • Quote
    • Vectorworks
    • Photoshop
    • Rhinoceros
    • V-RAY
    • Autodesk Revit
3. Monitors
1 ultrawide monitor.
currently, looking into either the Acer predator XR342CK Pbmiiqphuzx or the Dell UltraSharp U3415W
4. Peripherals
will be re-using kb + mouse; windows key is needed, but will purchase OEM key
5. Why are you upgrading?
I have no viable PC/Laptop for those applications, only macbook pro 2015 13" with the least performant specs.
When NVIDIA 3000 series / Ryzen 4000 comes out, I may look at selling previous parts now, and purchasing the newer ones.
For now, nothing is confirmed. It may be a while until these gpu/cpus comes out.
i made a list pre-configured, and I want to see if there's any way to reduce costs, bang for buck
since it's a workstation, there's a certain premium I understand I have to pay for upgrade features. that said, here we go:
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($636.95 @ shopRBC)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($44.75 @ Vuugo)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard  ($239.99 @ Newegg Canada)
Memory: G.Skill Aegis 32 GB (4 x 8 GB) DDR4-3200 Memory  ($191.99 @ Newegg Canada)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($169.99 @ Amazon Canada)
Video Card: EVGA GeForce RTX 2060 SUPER 8 GB SC ULTRA GAMING Video Card  ($609.99 @ Newegg Canada)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($134.99 @ Newegg Canada)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($179.99 @ Amazon Canada)
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140 mm Fan  ($33.46 @ Amazon Canada)
Monitor: Dell U2718Q 27.0" 3840x2160 60 Hz Monitor  ($920.99 @ Amazon Canada)
Total: $3196.55
Generated by PCPartPicker 2020-04-29 17:18 EDT-0400
https://linustechtips.com/topic/1186265-workstation-build-for-3drendering/
2. Aim
3. Monitors
4. Peripherals
Total: $3196.55
The hyper 212 evo is worse than the prism. If youre going to run the 3900x at 75%+ utlization for more than 45 minutes at a time you might want to consider a dark rock pro 4. The motherboard is fine, the RAM should be at 3600mhz, the nvme is solid, the Meshify-C isnt the best value anymore, but it works, Change the GPU to an aftermarket 5700xt, and hot damn is that monitor overpriced. If you arnt gaming at all, just @ me or quote me, and I'll make you a threadripper build instead.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
I'm potentially interested in a threadripper build, but I still do want an Ultrawide for viewing preferences, lol.
As for the GPU, I understand that NVIDIA is much better than AMD cards, due to their drivers and incompatibility with certain of these applications.
Could you let me know what is that Meshify-C alternative?
You realize that Monitor is a flat 27"?? AMD card incompatibility/driver problems have been fixed for a while. A good meshify-c alternitive is the Phateks P300a/400a
