OBS NDI (Network Setup) Problem
Solved by Falcon1986,
On 4/30/2020 at 7:58 AM, MyGetthoRig said:i connect directly via ethernet
I’m not very familiar with your app, but I can tell you that you just can’t link 2 PCs with a standard ethernet cable and hope to get a LAN. You need to use a special ethernet cable called a crossover cable, then configure internal IP addresses and a Windows workgroup at both ends.
Do you have the ability to wire both computers into a router/switch to share internet? That would be a simple method of establishing a LAN and not relying on a bridged connection to share internet access.
