Hello! Recently inherited a system with a i5 8400 and a Gigabyte 2060 OC. Playing games like Overwatch and NBA 2k it roughly split the load 50-60% CPU 40-50% GPU. However in games such as Warzone I was getting 95-100% CPU loads. I thought the normal assumption and assumed I was getting CPU bottlenecked. That's all fine except I upgraded to a 9600k earlier and I'm getting the same results slightly less CPU load though, more like the 80-85% range. I'm just confused because I've always been under the impression with gaming that GPU load should always be 99-100%. Has anyone had a similar experience?
https://linustechtips.com/topic/1185762-high-cpu-load-low-gpu-load/
