Hey guys, my PC is getting strange noise when folding project 16433, wondering any of you having similar issue.
Here's the video of it, sounds like a receipt printer or something.
And my PC part list:
Intel Core i7 8086k
ASUS PRIME Z370-A
4x16GB Corsair DDR4 3200 C16
EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING
Corsair MP510 1TB
Corsair HX1000i
Phanteks Eclipse P400S
I've been folding for weeks and never noticed such problem.
It seems only occurs to project 16433, other projects and gaming won't make such noise.
https://linustechtips.com/topic/1185336-strange-noise-when-folding/
try to narrow down the noise to a specific component and go from there
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Well, the WU making this noise was already done, and no other project is making this noise, so I can no longer specific the source.
Thanks for the tips anyway, I'll look into it if it happened again in the future.
Project 16433 appeared again and so does the noise. It's most likely came from PSU.
I checked the GPU usage curve and it matches the loop of the noise.
Maybe it is a coil whine and there's no way to fix it, but still curious why this only happens to FAH project 16433.
I hear that noise on some projects and while I encode video. I also have the 2080Ti FTW3 Hybrid. I suspect the AIO pump
11 hours ago, DonGuano said:
Coil whine?
I am also runing a 2080Ti, but the Strix Model.
Definitely coil whine. The tone of the whining depends on the WU.
I suspect the frequenzy at what the coils get switched resonates in different tones.
You even hear it with a waterblock, but damped.
🤟 compute the cure - emergency request folder 🚑
Stats: F@HBoinc
main system OC'd
| CPU: Intel i9 9900k | Motherboard: Asus Maximus XI Formula | RAM: 32GB (4x8GB) 3466MHz Corsair Vengance RGB Pro | GPU: Asus ROG Strix GeForce RTX 2080Ti 11GB |
| PSU: BeQuiet Straight Power 1000W | Case: Fractal Define R6 | Cooler: Custom Loop | NvmE: Samsung 970 Pro 512GB + Samsung 970 Evo 1TB | SSD: Samsung 860 Evo 1TB + Samsung 860 QVO 1TB |
| Monitor: Asus Swift PG279Q + BenQ BL2420BT |
Laptop: Asus TUF PX505G | CPU: Intel i7 8750h | RAM: 32GB (2x16GB) 2666MHz HyperX Impact | GPU: Geforce GTX 1060 6GB OC'd | NvmE: WDC 256GB (OEM) | SSD: Samsung 860 QVO 1TB |
2nd system (Wife) OC'd
| CPU: Intel i3 8350k | Motherboard: Asus ROG Strix Z390-I | RAM: 16GB (2x8GB) 2666MHz T-Force Delta RGB White | GPU: Asus ROG Strix GeForce GTX 980 4GB |
| PSU: BeQuiet Straight Power 550W | Case: NZXT H210 White | Cooler: Asus ROG Ryujin 240 | SSD: Samsung 850 Evo 1TB | Monitor: Acer XB270H + ACER Business B7 B277bmiprx |
3rd system (Surfdeck-TV)
| CPU: Ryzen 5 3400G | Motherboard: Asrock B450M-Pro4 | RAM: 16GB (2x8GB) 2933MHz HyperX Predator RGB | GPU: integr. Vega 11 | PSU: EVGA G2 750W |
| Case: MasterBox Q300L | Cooler: Noctua NH-U12S Ltt Edition | NvmE: Corsair MP510 240GB |
